Simplifying drawing template rework in 3D CAD modeling
Lessons involving zone parameters and revision tables lead to the auto-filling of zone cells
- July 29, 2022
Templates in a CAD system affect drawings, parts, assemblies, and various tables and forms. The best templates have professional appearance, save labor, and reduce error. The design of templates is an occasionally used skill, sometimes delegated to the intern.
This specialized effort is intense at the beginning of a project and then becomes a matter of sporadic maintenance. To put it another way, a learning curve occurs early on and is followed by re-learning curves.
Sidebar: A specific brand of mainstream 3D CAD is being discussed. As a matter of information, the add-in Template Wizard for this 3D CAD package is an excellent tool for designing and administering templates. I have no affiliation with that or any CAD product, but I was once fortunate and pleased to be on an engineering team with its developer.
The Template Wizard addresses the seldom-used aspect of template design. The learning curve for the add-in is more about understanding settings to achieve preferences and is less about the nitty gritty syntax of links using custom properties to share product manufacturing information (PMI) between files.
If you administer CAD projects that span turnover in staff and standards, you should at least be aware of the stability and consistency the Template Wizard offers.
For those interested in ad-hoc, nitty gritty, DIY template design, we now refer to a CAD project from previous episodes. In summary, templates from a variety of sources are being merged as part of supporting a new project—the imaginary FMA Cart.
Our drawing template has legacy, not quite as charming as having a fax number, but close. In the olden days before paperless manufacturing became the norm, final drawings were always printed and stored in a flat file.
Part of our template legacy is 22- by 34-in. paper, which matches ANSI C size. Figure 1A gives a sense for the size of text on the printed sheet. If we wanted a different sheet size, we would start with a different sheet format as a starting point.
From previous episodes, we have a good start on a data entry form to collect the PMI. Figure 1B is showing that form’s roll in the path of the description. It starts in the 3D model (PMI is entered and saved via a data entry form) and ends in the 2D drawing (text displayed in the title block). All of our PMI (material, author, etc.) follows a similar linkage.
With the brand of CAD being used, when a drawing file is opened, the drawing’s sheet format will be displayed, with the sheet format guiding the retrieval and display of the PMI found in the 3D model. In other words, the drawing is a container for the sheet format (border) and the various views of the model. There are templates for drawings as well as for sheet formats.
Sheet formats are protected from accidental editing. Sheet formats are edited much like an ordinary 2D sketch. Completed sheet formats can be exported and then can replace the sheet formats used by existing drawings or drawing templates.
Several CAD-oriented policy decisions guide our design of templates:
- The PMI is maintained in the component files.
- The drawing file displays (i.e., automatically fills in the title block) PMI found in the component’s file.
- Sheet 1 at the top right will have a revision table with zone coordinates.
- Subsequent sheets will have a dummy rev table stating, “SEE SHEET 1.”
- Sheet 1 will have proprietary declarations and standard notes; subsequent sheets will refer to sheet 1 whenever practical.
- All sheets’ title blocks are to be legible when printed on 11- by 8.5-in. paper (B size).
- All sheets are to have a perimeter border/zone grid featuring rows A-F and columns 1-8.
- It is expected that users of the template will scale the component views so that they fit within the border.
From the previous episode, updates are planned for the default notes and, perhaps, default tolerances. We’ll keep those edits on the to-do list. Revision table setup is more entertaining.
A revision table can have easy-to-add columns, fonts set, and widths set, and later can be saved as a template. That revision table template then can be inserted into a drawing template.
Revision tables feature labor-saving abilities. One of those abilities automates the data entry of the zone coordinates on the drawing where revision symbols have been added.
The drawing template we’ve inherited has a discrepancy with zone parameters for the revision table. In Figure 2, the column labels A-F are in a blue box. The column labels 1-8 are in an orange box. It is the quantity of labels, not the labels themselves, that are in error.
In Figure 2, the Sheet Properties dialog is showing Zone Parameters for the revision table, currently set to four rows and four columns. That is corrected to six rows (A-F) and eight columns (1-8).
Auto Update Zone
The epiphanous Auto Update Zone Cells setting for the revision table causes the table to automatically update the cells in the zone column based on the locations of the corresponding revision symbols.
In Figure 3, the results of the Zone Parameter setting from Figure 2 are shown. Note the location of the revision symbol (triangle around B) is in the sheet’s fifth row (labeled E) and second column (labeled 2). Thus, zone E2 appears for the REV B row in the table.
As might be noted with the preview of the template in Figure 1A, issues remain with font sizes, notes, and what is or is not PMI. Who needs a property for client? Don’t we know the name that should appear on the drawing?
